Subframe, wheels, paddle clutch, hubcaps, spring assisters, brakes, alternators
Started by Andy, September 25, 2011, 06:05:43 PM
I'm having a bit of a clear-out... All parts are located in Warwickshire, I'm about 5 mins from J12 M40 - I can arrange postage if required or possibly meet up.
Sensible offers accepted - I can only say no!
Sachs paddle clutch with OEM pressure plate. £80.
I used this on my G40 when running a G-lader on a 1341cc bottom end with BV head - had no issues with it slipping. It was originally from a 6N rally car and I got it re-sintered for £50. Only took it out because I thought this was the cause of a drivetrain rattle - but it turned out to be the gearbox instead... I'd already bought a Helix setup to replace it, so this has just sat on the shelf for a few years. There's some surface rust on the pressure plate (see pic), but this should clean up nicely.
Stage 3 PPP Prototype Subframe with TCAs and Powerflex bushes. £400.
This is the original UK-produced subframe that we prototyped on my car. It uses a standard gearbox mount as the rear hoop is clearanced to fit around this - later production versions used a new gearbox mount to ease the production process. Only removed from my car because I couldn't run it with our prototype adjustable TCAs - the TCA mount uses an M10 captive nut on the frame, and our adjustable TCAs use M13 bolts.
Please note that price includes a decent set of TCAs with Powerflex bushes.
Set of new rear brake shoes for 86C Polos. Jurid branded - subsiduary of OEM tier 1 supplier Honeywell. £10.
I bought these at the same time as a new handbrake cable for the MOT, forgetting that I'd already fitted new rear shoes the previous year...
Pair of new brake drums for 86C Polos. Vetech branded. £25.
Brand new, not taken out of packaging. Cheaper than GSF!
Set of 4 Speedlines, 14" x 6" ET38. £200 - tyres extra.
Sandblasted and powder coated satin black, not some pikey Nitromoors and rattle can "refurb". Centre caps have been rattled canned though - matt black. Only for sale because I got some Compo MOs as part of a deal on another car!
They will have the new tyres removed to go on my MOs, but I can put on a set of 185/50 R14 A539s for the buyer at extra cost. Two are 2-3mm of tread, two are 4-5mm of tread - see photos for examples.
Polo alternators, new Halfords, used Lucas. New £45. Used £15.
Grayston spring assistors - stiffen up a set of springs! New £25.
Very handy for trackdays or drag strip use when you might want to temporarily stiffen up the rear springs - or maybe if you've got scrubbing issues. They're £15 each in Halfords, and these are brand new. Bought them for Santa Pod to supplement the existing pair I'm using, but I couldn't fit both sets in!
Coil spring clamps. Pikey/temporary raising or lowering. New £15.
New and unused. Bought to lower a car at work for the Geneva Motor Show, but they cut the springs instead so I couldn't flog them these!
Hubcaps/wheel centres. £10/set.
Jetex airfilter element for Saab 9-5 Aero. £10.
Might be of use to someone?! I took it off my daily to clean and re-oil - and ended up using a standard filter element anyway to make it quieter.
Will ask Mike when he gets back from holiday- but fairly sure he'll have the paddle clutch.
Andy, do these wheels clear the compression struts on the subframe when on full lock or are spacers required ?
Etches
Quote from: dub-disaster on September 26, 2011, 03:43:59 PM
On my car with the way I had the frame set, they caught very slightly on one side - a 5mm spacer would give more than enough clearance.
Andy's in India with work currently, not sure if he's got internet access at the moment Rich.
Andy- Dibs on those drums too!
Yoof if you can get in contact with andy i'll have these wheel off him. Coming past his way in a couple of weeks so can pick up then. Wwill drop him a pm incase he has got internet access.
If jezzas doesn't take those rims I'd take them aswell but he's got first refusal.
G40_Mike_
I'm interested in the wheels, have you ever run them with larger calipers? I have the Willwood midilite kit coming, any idea how these perform?
I'd be interested in a wheel and subframe deal.
Mike
Any news on wheels andy? Coming up to leamington this week/weekend so can pick them up then.
Apologies for the slow response guys, I've just got back from a trip to India with work.
Wheels provisionally sold to Jezza-7. (You have PM back!)
Drums and clutch have gone.
Subframe and other bits still available.
G40_Mike_
