Gladerseite vs Super Pro vs Powerflex
Started by Breaderzz, September 21, 2011, 01:21:58 AM
Breaderzz
As per title really, need to replace mine. Any experiences, especially from those who have used more than one type greatly appreciated.
Will be using with ARB blocks.
Cheers, Liam
grungeisdead
Afaik super pro n powerflow only do standard replacement bushes, not blocks. So wont correct the geometry of a lowered car
Phil
Quote from: Breaderzz on September 21, 2011, 01:21:58 AM
Gladerseite bushes are nylon meaning they are very stiff and will reduce ride quality. Powerflex outter bushes are a poor design and will rip up in no time. A friend with a 55hp coupe s broke a set within 1k hard miles, G40's eat them right up.
Breaderzz
Quote from: grungeisdead on September 21, 2011, 02:06:06 AM
I shoukd have been clearer. Will be running arb blocks from gladerseite, trying to decide on tca bushes, obviously the the gladerseite ones will involve getting rose jointed tcas.
Basically want abit of feedback, on the differant types. Life span, improvment, value for money etc.
Cheers, liam
grungeisdead
you dont need to get rose jointed TCAs to run the G-ladersiete outer bushes, although using G40 items are better to start off with.
ive ran with both in my time, and as phil has found, the powerflex ones have torn, which isnt good!
Breaderzz
Quote from: grungeisdead on September 21, 2011, 12:11:23 PM
So what would you run on the inner bush? As obviously the gladerseite ones are only the outer ones.
grungeisdead
i run rose-jointed G40 tca's. but the gladerseiete TCA's look good if a little pricey. probably worth it, as finding decent G40 tca's is tricky these days
g40s have rose-joints in the inner TCA anyway, or do you not have the normal g40 TCAs?
Breaderzz
no ive got a GT.
But im planning on converting it so when i replace things im looking to replace them with things that will be good enough for when its converted.
