It does indeed!
First off the manifold requires a smaller oil filter (especially if you have an oil cooler take off plate) and heat shielding between the oil filter and manifold (it's very close)
Second the downpipe is a laugh, points stright into the block/sump and doesn't fit.
Oil banjos are wrong for the BB Turbos (needs an expensive £30 banjo, not included)
Water lines require modification to fit (the ends)
Boost pipes I didn't even bother with the stuff he sent....
Only parts worth having are the intercooler, and the manifold. But be prepared to modify parts.
