Please help running problem still
Started by matthg40, September 09, 2011, 08:25:16 PM
matthg40
Rite here goes when my 40 drops below 1000 revs it stalls I ve checked all earths and now I'm stuck I can do anything with my eyes closed on my polo but soon as it comes to electrics I'm stuck if anyone has pointers for me please suggest many thanks matt
AlexG40
matthg40
Yes mate I've swapped everything over from my old polo to a  rolling shell do the engine came out in one piece so I'm still stuck lol
matthg40
I've. Checked vacuum leak throttle body all perfect pal
matthg40
I've just took my g out and notices that the headlights are flickering like mad is this linked
AlexG40
Could be, the voltage to the ECU is critical...
matthg40
Ah well I'm baffled then matey I dontnno what else to try
cheys03
It could be 1 of 1000 things.
In honesty, as you admit you're not experienced with electricals and electronics then I'd be tempted to take it to a well-know and recommended car diagnostician.
matthg40
Yer I was thinking that mate one last thing where is my isv as I have never cleaned it and touched it that could be part of the problem
cheys03
ISV is below the inlet manifold, bolted to the top of the water pipe that runs along the back of the block
matthg40
Peterpolo
Also check your alternator charge rate and battery with a vm, the car will run crap if it's undercharging and that would proberly explain your lights flickering too!
matthg40
Any idea what the charge rate should be pal
should get a good 13v or more across the battery terminals with engine running and everything electrical switched on, headlights, heater fan, rear window demister etc...
matthg40
Thank you for that mate will get the multimeter out later
