turbo oil drain fitting (the one you weld into the sump)
Started by youngprodigys, August 10, 2011, 10:25:12 AM
youngprodigys
hiya guys, the the size of the fitting which you weld into the sump?
im having my pipe custom made but i want to make a start on making the sump as it will be one of the first jobs i do.
what did everyone else use? any links to products/ ebay items would be great.
only post up what you used as i dont want guess work;-)
cheers
KiZ
Mines the oem passat drain pipe with the bottom section cut and re welded to suit the length, then a flat plate welded on the sump with two dome nuts for the flange to bolt too. The oem pipe is realy good solid either end with a flexi in the middle and a flat two bolt flange either end.
breadman
cheys03
I used some 16mm ID (from memory, same as the OEM ID anyway) tube that was already bent to the correct shape, cleaned it up and brazed it into the sump. The turbo-end was a cut-down OEM pipe joined with some rubber oil hose 2mm ID too small to ensure a tight fit clamped with jubilees. No leaks :)
The sump-end of the tube was a piece of old deck-chair :D
Quote from: breadman on August 10, 2011, 06:28:31 PM
Can you get a picture up of the above Anthony?
Will get some photos when I next go to the garage, although you have to excuse the instant gasket over one of the bolt heads on the flange as me being the monkey I am overtightened the bolt and striped the thread  :(
Here's the sump fitted with a blanking plate after it was powder coated.
youngprodigys
looks to messy for me, im an sad perfectionist.
ive got a 3/4" BSP fitting im going to weld to the sump now and use a custom made line
I would prefer a fitting welded on aswell, when I change turbo I will go this way but I do like using the oem line as it's mainly solid and good quality and isn't too pricey to buy or replace.
I just welded a fitting to my sump:
can't remember what size it was though.
youngprodigys
thats more what i was planning!
looks like i have the same size to. thanks mate:-)
youngprodigys
yer i seen that.
made my own lines now so when ive welded it all in il get some pics up
prankstar2003
Sorry to hijack, but where do you take the turbo oil feed from?
cheys03
Back of the head, where the oil pressure sensors are. T-piece into one of them. M10x1mm thread.
prankstar2003
#14
Lovely, thank you very much.
Why do you need to tap/attach a return to the sump? Why cant you use the normal oil feeds/returns on the g40 block?
