g40 pistons ?
Started by boyzey, August 05, 2011, 04:52:50 PM
boyzey
oryt people just after identifiying a set of pistons am hoping they are g40 ones  :), do they have a specific part number or is it a case of putting them side by side with gt pistons, any help wuld be great cheers
boyzey
any help please or even ideas
I got some laying around. Give me a number and photo if you can. Will check tomorrow.
boyzey
havent got the pistons wiv me at mo mate, but if ther is any numbers on urs it would be much apriciated if you could send them on and i can check with myn wen im next down with them, do you recon you could tell difference just looking at them then m8
thanx for reply
Er i dont know. I believe all mk3 polo con rods are the same, except the 1w ones as they have a longer stroke. So maybe all 1292cc pistons are the same?
youngprodigys
all the same except for 1w which have a larger 20mm pin
willsalter1000
Quote from: youngprodigys on August 13, 2011, 10:10:47 PM
1w engines have a 22mm pin, all others are 20mm
boyzey
oryt thanx for all replys so basicaly as far as i was aware all con rods are defo same, no that some 1 on hear sed that crank shafts could possibly be ever so slightly different but so small you wouldnt notice, and i thought that pistons wer specific to g40 for compression  ???
pistons are specific, conrods same. crankshafts are different, (dif part no)
boyzey
oryt pete thought pistons were the differance ye cheers for that you dont no how to identify g40 pistons from say gt ones do you i got a set and wana no wat they are cheers
Daryl
G40 pistons dont have groves cut out 3f, aav etc do
