wheel size
Started by Adampolog40, July 30, 2011, 09:55:11 PM
Adampolog40
hi, looking to fit a set of bbs rs 15"x 7" front and 8"s on the rear not too sure what et i may need fitting g60 brakes also if that matters
any advise would be great thanks
et aside your arches will need some serious work to accomodate these and avoid ripping your tyres to shreds in my opinion (anything over a 6" wide 15" wheel normally does)
G60 brakes dont fit straight either as the bolt spacing is 100mm on the carriers and a polo is 76mm
Adampolog40
i have had the arches rolled and i have the spacers i need for the brakes
breadman
If you need to use spacers to clear the brakes the wheels will stick out even further. This will make things even worse.
As Pete said, 6" wide with a near standard ET is plenty wide enough. Why try and fit something that clearly doesn't fit unless you cut the car about and then only compromises ride and handling? Regardless of arch rolling/trimming, wheels this size will rub.
Adampolog40
fair comments! thanks time for a have a re think
