Author Topic: Boost gauge  (Read 3761 times)
Offline Jake G 4 0
  • Rebuild time almost over
Boost gauge
« on: July 19, 2011, 05:40:30 pm »
As above really I have t'd it into the FPR vacuum pipe and I was just wondering if this is the correct place??
Pics as well please.
Thanks Jake.
Offline ereeiz
Re: Boost gauge
« Reply #1 on: July 20, 2011, 12:06:09 pm »
I put my T piece in about 2-3 inches from the ECU.
Re: Boost gauge
« Reply #2 on: July 20, 2011, 12:53:01 pm »
FPR pipe is the better one to use.  the cleaner the vac signal to the map sensor in the ecu is the better so I'd not tamper with that pipe.  It is intentionally a specific length too
Offline grungeisdead
Re: Boost gauge
« Reply #3 on: July 20, 2011, 01:54:43 pm »
is it possible to use the take-off thats normally blocked off with the BRV mod, front on the throttle body for the boost guage (and poss dump valve for those with turbos) and leave the FPR and ECU vac lines well alone?
does the FPR to the take-off on the brake servo want to be a specific length as well?
Re: Boost gauge
« Reply #4 on: July 20, 2011, 02:09:07 pm »
FPR isn't anywhere near as sensitive as a map sensor, it's just a diaphragm with a spring behind it so I'd not really worry about introducing any slight fluctuations in the vacuum signal to that.  Pretty sure ETKA doesn't list a pipe length to the FPR whereas it does for the map sensor
Re: Boost gauge
« Reply #5 on: July 20, 2011, 02:33:18 pm »
cool, ta paul!
Offline Peterpolo
Re: Boost gauge
« Reply #6 on: July 20, 2011, 02:48:15 pm »
I'm pretty sure the little hose to ecu is ment to me 1 mtr long! You should put the t-piece on the fpr and not on the ecu hose!
Re: Boost gauge
« Reply #7 on: July 20, 2011, 03:17:19 pm »
no.  On a g60 it is something like 900mm but a g40 one is shorter, 600-odd I think.  The length is in EKTA/VAGCAT.
Offline ereeiz
Re: Boost gauge
« Reply #8 on: July 20, 2011, 03:48:09 pm »
I'd forgot about that! I can't say I've noticed any problems and been running it for a few months. Apart from the little hesitation on idle/acceleration. I wonder if it's related to that?
Re: Boost gauge
« Reply #9 on: July 20, 2011, 03:58:28 pm »
might be, VW list a very specific length for some reason
Offline Puncharado
Re: Boost gauge
« Reply #10 on: July 20, 2011, 06:55:59 pm »
ECU vac hose is 470mm. At least mine is, and it hasn't been cut to my knowledge.
Offline Jacque
Re: Boost gauge
« Reply #11 on: October 05, 2011, 11:35:37 am »
Hi, a little off the subject, but didnt want to start a whole new topic for it:
I would like to place a boost gauge, but i really don't want to "sacrafice" my radio slot for some gauges.
where did you guys place yours? i m not really into a fancy gauge on top of my dash, i would like to stay as close as possible to the original looks..
Offline ereeiz
Re: Boost gauge
« Reply #12 on: October 19, 2011, 05:44:00 am »
Mine is still temporarily cable tied in kinda hanging out/ resting on the ashtray. I say temporarily...........I think it was June I put it in "just to see what boost I get" lol.
