Author Topic: will this master cylinder fit?  (Read 1893 times)
Offline hooblah
« on: July 19, 2011, 04:27:48 pm »
Re: will this master cylinder fit?
« Reply #1 on: July 19, 2011, 04:38:07 pm »
no its not you want a late spec 16v golf mk2 one - the 22.2mm one
and the mod only reduces pedal travel (and makes braking a bit harder)
Offline hooblah
« Reply #2 on: July 19, 2011, 04:58:21 pm »
Well my pedal goes really far down, its been bled so im assuming the master cylinders had it. There may still be some air in it, is there an easy way of checking?
Offline scotsjohn
« Reply #3 on: July 19, 2011, 05:26:39 pm »
More likely your brake shoes are needing adjusted; the auto adjust on the polo's pretty poor.
Offline hooblah
« Reply #4 on: July 19, 2011, 05:48:20 pm »
Ahhh now thats a possibility. It started doing this after the shoes were replaced!
How do i adjust them?
Offline ereeiz
« Reply #5 on: July 20, 2011, 12:05:11 pm »
I remember reading somewhere go in reverse quickly and slam the brakes on hard and it shocks it into adjusting. not sure if that's hearsay or what though. Opening them up and setting them is the best way I'd ahve thought, you can check stuff too and clean excess dust out, etc.
Offline grayg40
« Reply #6 on: July 20, 2011, 12:29:53 pm »
you can adjust the shoes without taking the drum off again. take the wheel off and with the hand brake off, look through one of the wheel stud holes and you can see the tapered wedge with a spring attached to the bottom of it. if you can get something strong enough with a point (i buffed a screw driver) on it its pretty easy. stick the point in the hole on the wedge where the spring locates and wiggle it down wards till you get the correct adjustment.
There might be an easier way i don't know
Offline hooblah
« Reply #7 on: July 20, 2011, 07:03:38 pm »
I'll give it a try, thanks guys.
