Author Topic: car wont start..no spark  (Read 3128 times)
Offline alan gorst
« on: July 18, 2011, 07:16:14 pm »
hey all my g has decided not to start :( the cam shaft sensor , coil leed , plugs and dizzy cap are all good :) the coil is getting power but still i am not getting a spark :( i tried a coil off a 1L mk3 polo and a coil off a 1.4 8v 6n polo and still no spark ( i got told both these coils should work) so if thats the case does anyone know what my problem could be? could it be my ecu ? since its the only other sender for the coil? (if im correct in saying that :S ) any help will be muchly appreciated.
Thanks Alan
Re: car wont start..no spark
« Reply #1 on: July 18, 2011, 07:19:35 pm »
cam shaft sendor? do you mean hall sender?
Offline Boris
« Reply #2 on: July 18, 2011, 10:06:07 pm »
Check the pin clasps inside the connector from the loom to the hall sender.  I had the same problem and one of them had been pushed back and wasn't making a good connection.
Offline alan gorst
« Reply #3 on: July 19, 2011, 07:22:48 pm »
thanks everyone for your help :) problem is now resolved :)
so please delete thread :)
Thanks Alan
Offline Boris
« Reply #4 on: July 19, 2011, 08:16:48 pm »
How did you resolve it?  Might come in handy for someone with the same problem.
« Reply #5 on: July 20, 2011, 09:21:52 am »
yes Alan please post up the solution so that in the future other people can find this if they have the same problem.  That's the idea of a forum, it's not just to come onto to ask questions right away it's also builds a database of problems and solutions and people can use the search to find them.
And deleting threads once you've done with them would defeat the object of the forum.
« Reply #6 on: July 20, 2011, 10:07:22 am »
was the hall sender reading his other threads!
Offline LightDiodeNEAL
    • www.lightdiodedesigns.co.uk
« Reply #7 on: October 20, 2011, 09:02:06 pm »
My hall sender packed up the day I bought my G40... Less than 30 miles I'd done, must be common as .... :-|
NEAL
