g40 £1000
Started by tomsg40, July 15, 2011, 12:06:36 PM
tomsg40
hi guys iv got another advert in this section for same polo but just after putting that advert up the supercharger decided to fail so im in dilemma because i need a van for work,the other advert is headed under tornado red g40 theres nothing wrong with the car apart from supercharger is busted its going for £1000ono so if anyone is interested in it give me a call on 07891382748 or 01420 86004 cheers Tom
When you say gone - how do you mean - in a million peices - or smoking loooads of oil etc?
dekerf1996
Have you sorted the problem with the bottom end out, that was giving strange compression test readings?
Is the car drivable?
tomsg40
im not sure if i will describe it right but where the seals sit its worn away so everytime new ones are put in they just fail and i havnt got the time to sort everything out so iv got to sell it and as for the boottom end when we redid the supercharger i took it out for bout half hour drive and it felt perfect there was no smoke until obviously the charger started leaking oil
xandyx
when you re-assemble the charger, do you use to put some engine oil on seal lip before putting the axle in his place?
maybe it's just too dry, and when it rotates, overheats the compound and melt the lip..
grungeisdead
axle?
engine oil on the seal?
you serious?
means on the charger seal - and axle.
To be honest more likely the scroll seal housing is likely to be scored.
tomsg40
i think your rigt pete my mate redid it he said it will just keep goin through seals.
i've come across one whereby the it was the oil slinger in the charger not going round so blowing seals... could be a variety of things.
tomsg40
ye i was just going to change it to turbo so its slightly more reliable? but iv just gone self employed so i need to get some money together to get a van
tomsg40
ok big change of plans im going to be open to offers on the polo the only problems are the supercharger needs replacing or mending if possible and i had comp test done and the results wer 1=175psi 2=175psi 3=100psi 4=75psi so if anyone wants to give me any offers just pm me or give me a ring
Whereabouts are you?
Breaderzz
text the chap yesterday and apparently its sold already.
tomsg40
ye sorry should of put somin on here the cars been sold and getting fixed sorry
