Author Topic: Knock Sensor  (Read 5072 times)
Offline Nick_S
  • 189.6 bhp @ 8psi boost
Knock Sensor
« on: March 18, 2008, 08:12:07 pm »
I can't seem to find a knock sensor torque setting in Haynes. Anyone know what these Bosche ones need to be nipped up to?
Got all the surfaces nice, clean and fresh so it should work effectively.
Re: Knock Sensor
« Reply #1 on: March 18, 2008, 08:24:57 pm »
Tight, their effect is minimal upon digifant- I'd use a more modern sensor if you're still planning to run aftermarket management.
Re: Re: Knock Sensor
« Reply #2 on: March 18, 2008, 08:51:39 pm »
'tis in Haynes.  In the ignition system section: 20Nm or 15lb/ft
Offline Andy
Re: Re: Re: Knock Sensor
« Reply #3 on: March 18, 2008, 08:56:55 pm »
Not worth running one IMO, bit of an arcaic way of trying to detect knock - and if it actually worked properly why so many melted pistons? It's just a microphone with some amplifier circuitry and a shitload of filtering to try to make some sense of all the crap it picks up. Your ears are a much better tool!
To do it properly there are systems that look at induced voltages across the plugs - that's how the system in my Saab works, allows it to adapt the boost and ignition curves to the type of fuel you're running. Fairly sure that's the standard way of doing things now, either that or measuring cylinder pressures directly with pressure transducers in the HG - though from what I've seen that's more of a development tool, not sure any OEM uses that.
Offline Nick_S
Re: Re: Re: Re: Knock Sensor
« Reply #4 on: March 18, 2008, 09:55:55 pm »
Cheers.
It will do for now. I shouldn't be melting pistons in the near future :)
