Aquamist part kit
Started by Jezza-7, May 29, 2011, 01:03:19 PM
Bought a kit about 2 months ago with the intention of fitting it for my remap but im not fitting it now. I think it will cause more problems as i use my car as an "almost daily".
So it is a devils own kit. It is 2 years old and was fitted to my friends mx-5 for about a year and half. Only used during the weekends.
The pump is a 150psi at works well as i have tested it.
The only things i can think of that you will need to buy is the nozzle as i never got round to buying it. It has a check valve but its an old style one so i would recommend buying one of the new ones.
Pressure switch has been set to 6psi and has 3 different settings depending on when you want the pump to kick in. I think its 3,10 and 30. The pressure switch has got a t-piece so you can plumb it into your vacuum line.
Wiring is all there and i have printed off a set of instructions so it can be connected properly. It also has a separate wiring harness which is needed if the tank is higher than the nozzle to prevent siphoning under vacuum.
Will need to buy the nylon hosing for the kit as i got very little with it but depending on where your going to mount the pub i.e. boot, you will need a lot. Will get pics of the kit so you can see what there is.
Nozzle is £16
Check valve is £25
Filtered self sealing tank tap is £15
Nozzle holder is £8
This is what the kit is http://www.methanol-injection.co.uk/product_info.php?cPath=21&products_id=28
£220 new and with the above needed to buy to complete the kit would be £64 so i will sell the kit for £120 posted, or if collected i can also give about a gallon of pure methanol.
Location Somerset.
