Author Topic: 1341 Headgasket  (Read 3940 times)
Offline stuG40
1341 Headgasket
« on: May 26, 2011, 12:40:54 am »
Can anyone point me in the right direction to get a 2mm oversize standard headgasket?
i tried TPS but they don't go that big, gsf also said they cant get one.
what headgaskets are people using to build there 1341 bottom ends?
i want to try and keep the headgasket standard size to keep the cr standard as i'm using wossner pistons.
cheers guys...
Offline dub-disaster
Re: 1341 Headgasket
« Reply #1 on: May 26, 2011, 08:04:34 am »
I use a standard one think a few others do aswell, you'd be fine to use a metal one aswell it will only raise compression to 8.2-8.3-1 which shouldn't be a problem especialy if it's still supercharged
Re: 1341 Headgasket
« Reply #2 on: May 26, 2011, 08:15:06 am »
yeah - either stock g40 one with g40 headbolts or 8v mk4 on (metal one) with stock size head bolts will be ok for an overbore.
Re: 1341 Headgasket
« Reply #3 on: May 26, 2011, 11:26:19 pm »
Use G40 headbolts- there's a good reason they cost more...
Offline cheys03
Re: 1341 Headgasket
« Reply #4 on: May 26, 2011, 11:56:12 pm »
Is it just that they're slightly longer to accommodate the thicker G40 head gasket Pete? or is there more too it than that?
Offline stuG40
Re: 1341 Headgasket
« Reply #5 on: May 27, 2011, 12:23:09 am »
cheers for the info guys, but vw don't seen to do a 77mm bore with the standard headgasket.
if i use the metal headgasket from a mk4 8v, does anyone know the engine code or part no. to quote them?
and is this still possible to use the G40 headbolts with the metal gasket?
also, when i striped my engine, the camshaft had "PSD G40 P3" stamped on the side of it, i think this may be the eaton cam that they once sold when they were in business, but will this cam still be ok for the 1341 rebuild? ( p.s im using the eaton m45 charger for now, as i bought the car with this charger)
cheers . . .
« Last Edit: May 27, 2011, 12:25:26 am by stuG40 »
Offline Jezza-7
Re: 1341 Headgasket
« Reply #6 on: May 27, 2011, 06:17:31 am »
There longer but thats not the reason. The tensile strength is different. The shorter ones are 8.8 and the longer g40 ones are 10.8 iirc.
Offline Jezza-7
Re: 1341 Headgasket
« Reply #7 on: May 27, 2011, 06:18:59 am »
Just ordered one mate. Its about £29.
You need to say its a 1.6 8v polo engine code AEE. I will have a quick look around for the part number as i have it somewhere.
Re: 1341 Headgasket
« Reply #8 on: May 27, 2011, 07:13:31 am »
Listen in class! G40 are 10.9  ;D
Robin got me the drawings for both bolts, as he was trying to be a pikey and save the cash, interestingly the drawing also shows a different torque/angle to pull, giving the gasket more clamping load- to cope with higher cylinder pressures. Haynes just says one torque for all... ::)
Offline Jezza-7
Re: 1341 Headgasket
« Reply #9 on: May 27, 2011, 07:53:33 am »
Damn lol, 0.1 out. The part number is 030 103 383H
Didnt realise they had a different torque angle. So is it still stage 1 40nm, stage 2 60nm then either 2 lots of 90 or one turn of 180?
Offline cheys03
Re: 1341 Headgasket
« Reply #10 on: May 27, 2011, 08:02:55 am »
Ahhhh, good info!
Anyone know the damage from the dealers these days per G40 bolt?
Re: 1341 Headgasket
« Reply #11 on: May 27, 2011, 08:04:38 am »
I just used non g40 bolts with a g40 gasket :( does this mean I'm going to hav head gasket failure in the not to distant future. I was trying to be a pikey and save cash two as g40 ones are pretty expensive. Around £5 each I think  !
Re: 1341 Headgasket
« Reply #12 on: May 27, 2011, 09:16:35 am »
i have some g40 pattern part ones - which are actually longer, but will see if they are marked for strength.
yoof - you should put the torques up here if you could, would make interesting reading.
Re: 1341 Headgasket
« Reply #13 on: May 27, 2011, 09:25:28 am »
confirmation at last!  Care to post these pictures up?
Re: 1341 Headgasket
« Reply #14 on: May 27, 2011, 10:58:17 am »
are these on elsa?
