Problem with CD player
Started by langersG40, May 21, 2011, 04:16:04 PM
langersG40
I'm having trouble getting my Sony cd player to work it's becoming a pain I know I have power to the unit as as soon as it's plugged in I can here it working but no sound or lights at the front does anybody know what all the coloured wires mean on the vw wiring loom??any help I would be most grateful
Regards
Chris
AlexG40
Sony units wire up in an odd way. I presume you're using an ISO connector loom or has someone butchered your factory plugs?
langersG40
Yeah I'm using a iso connector I defo have power as soon a I plug it in you here the cd player work but nothing comes on the screen the cd player works fine as it work fine in the wifes car
AlexG40
Right, and this is totally from memory so you may have to tweak it but I'm pretty sure I've had this before and it's to do with the yellow power/earth wires that you have to join up out side of the ISO connector (the ones with the thick pvc boots on). IIRC there are a couple of different configurations that are possible and getting it wrong can make the internals work with no display.
86C
Usually with Sony units, you have problems with the wiring which affects the memory storage for settings and radio stations etc. This is usually cured by swapping over the red and yellow wires on the Sony loom. Not heard of any issues with no sound or display though...
AlexG40
Yeh, I think what Steve is saying is right and is what I was thinking of. I'm sure it gave me the OP's symptoms in my case. Was a few years back now though and I'm getting old...
