Author Topic: golf mk3 pulley  (Read 3200 times)
Offline xandyx
golf mk3 pulley
« on: May 12, 2011, 02:44:37 am »
hi there!
i've been looking for a smaller pulley to fit my charger, and as i was looking for it i found this:
sorry for the portuguese content, but you'll get the point!
http://www.custojusto.pt/Porto/2020624-Polies+Volkswagen+Polo+III+1+0.htm?
do you guys think this is a good way to move from twin v-belts to 5pk belts?
will pulley's be the same size as polo g40 standard?
will they match a corrado g60 65mm pulley?
andré
Re: golf mk3 pulley
« Reply #1 on: May 12, 2011, 07:13:07 am »
not sure - but G-ladersiete do a full ribbed belt set.
I think the charger pulley on a g60 is offset by a different amount
pete
Offline Justin14100
Re: golf mk3 pulley
« Reply #2 on: May 12, 2011, 09:16:20 am »
be aware that in Portugal they somehow run much, much smaller pulleys than us, down into the 50's is the norm there.
Offline xandyx
Re: golf mk3 pulley
« Reply #3 on: May 12, 2011, 05:06:42 pm »
yeh, lots of people run 60mm, 58mm and 55mm pulley. lot's of chargers blowing arround here. i'm gonna get a 68mm or 65mm. no way getting smaller than that.
but if crank pulley and alternator pulley have the same size as g40 ones and the same offset, do i get advantages using it?
Offline Justin14100
Re: golf mk3 pulley
« Reply #4 on: May 12, 2011, 06:31:24 pm »
less slip on 5pk so a little more power, if they are an alloy pulley they will be lighter.
So do many chargers blow in portugal then? I wanted to go down to a 62mm toothed setup but dont want to cause a hellish amount of damage.
Offline xandyx
Re: golf mk3 pulley
« Reply #5 on: May 13, 2011, 01:07:45 am »
yeah, lots of people look for huge boost, so smaller pulley, and then, they pay the buck!
i don't trust in something smaller than 65mm. rather get the charger ported besides going smaller on pulley.
Offline ereeiz
Re: golf mk3 pulley
« Reply #6 on: May 13, 2011, 06:07:00 pm »
Going back some time I'm sure I remember seeing a graph of air flow or calculations on here or PSD and it showed that it was pointless going smaller than 60-65 (may have been 62?) mm as it couldn't flow any more air and it was turning over too quick/ blowing seals?
I really shouldn't smoke so much, I'd remember a lot more, hahaha
Offline Justin14100
Re: golf mk3 pulley
« Reply #7 on: May 14, 2011, 01:05:28 pm »
I'd love to see some air flow calculations, i think a lot was lost on the PSD forum, sadly.
