Author Topic: Uprated Driveshaft V2 Single orders accepted 2019  (Read 65868 times)
Offline Karlos the jackyl
    • VW Polo
Re: Uprated Driveshaft Single orders accepted 2013
« Reply #90 on: December 29, 2018, 11:32:10 am »
I'll investigate this again in the new year
Offline dazzle53
« Reply #91 on: December 30, 2018, 10:09:18 am »
Brilliant. Looking forward to an update.
Offline vwmk3jon
« Reply #92 on: January 03, 2019, 09:02:12 pm »
Me too.
    • VW Polo
« Reply #93 on: January 04, 2019, 11:03:58 am »
Does anyone have a stock driveshaft spare that I can loan / borrow to use for the tooling... I thought I had a spare but I think it got binned. Im in Hertfordshire if anyone is local.
Offline dazzle53
« Reply #94 on: January 04, 2019, 01:37:19 pm »
Not sure if I do but I will have a check and see and get back to you.
    • VW Polo
« Reply #95 on: January 09, 2019, 09:19:15 am »
Thanks , I've sorted one now
Offline RyanC
« Reply #96 on: January 27, 2019, 11:01:28 am »
A little feed back on the shafts. Work prefect for me but I did add a stop to each end so you could use the concave washers to stop the joint moving on the shaft. Mine had a lot of movement before and actually produced a noise due to the inner cerclip knocking against the joint over bumps where it was able to float on the spline. But nothing a few hours couldn’t fix though  🙂
    • VW Polo
« Reply #97 on: April 18, 2019, 12:47:45 pm »
They are back by! Uprated Heavy Duty Racing Driveshaft!!
Running a high powered Polo? Its only a matter of time before you snap a driveshaft!
Volkswagen Polo Heavy Duty Racing Driveshaft Fits Volkswagen Polo  MK1 - Mk2 - MK3 - 86 - 86c - Mk2f from 1975 - 1993
This heavy duty driveshaft is designed for the fast street or race drag Volkswagen
We released the original driveshaft design in 2001 to overcome the breakages experienced when slick tyres / Limited  Slip Differentials are used with the standard polo driveshaft. Since then it has been proven to be the choice of drivetrain to deliver reliable high performance results for both fast road and track racing around the world for 18 years!
This unit is manufactured from a single piece of high-grade aircraft quality material and heat cycled to provide a durable tough finish (blue flame glazing).
The driveshaft is compatible with all of the standard polo components and requires no modifications to fit.
These are currently in stock and can be purchased using Paypal by heading to  over to
https://www.mk1polo.com/
Priced at £199.95 with free speedy delivery to anywhere in the UK!!
Use the code : GLADER at the checkout you will recieve an EXTRA  £5 off !
Any questions feel free to contact me
Regards
Karl Tull
    • VW Polo
« Reply #98 on: April 20, 2019, 10:22:51 am »
Thanks Ryan
The lastest v2 design uses the stock seat on an end and is working well.
Regards
Offline vwmk3jon
Re: Uprated Driveshaft V2 Single orders accepted 2019
« Reply #99 on: May 08, 2020, 10:50:52 am »
Ordered one yesterday so will hopefully be able to give some feedback soon.
Offline G40Nik
« Reply #100 on: July 25, 2020, 11:09:19 pm »
anymore Feedback on these Drivshaft? Looking at getting one.
    • VW Polo
« Reply #101 on: September 09, 2020, 02:18:56 pm »
Head over to the facebook page for the latest info
https://www.facebook.com/groups/1168111519875411/
Offline quiksilver_jake
« Reply #102 on: August 23, 2021, 10:52:57 am »
Any updates for the v1 shafts ? I've just come to use mine after a good few years of storage and I now need to get it welded and machined to fit as Ryan mentions above. So not a straight fit 🙄
Also your site mk1polo.com seem unaccessible?
« Last Edit: August 23, 2021, 03:04:09 pm by quiksilver_jake »
