Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Turbochargers
Boost gauge feed
« previous
next »
Pages: [
1
Go Down
Author
Topic: Boost gauge feed (Read 3088 times)
Winston
Boost gauge feed
on:
May 03, 2011, 04:03:30 pm »
One more question if you please.
Would it be possible for me to take my boost gauge reading from the one way valve for my servo or will that be to weak?
My problem is the hose bores are a different size on acctuator piping.
Thanks again
Winston
ereeiz
Re: Boost gauge feed
Reply #1 on:
May 03, 2011, 04:32:08 pm »
I took mine off about 2" before the ECU. You can get T-pieces that vary in size/ diameter. Try a pet shop/ garden centre in the aquarium section to avoid paying daft prices, should be less than £1
Administrators
The CV joint killer
Reply #2 on:
May 03, 2011, 05:01:30 pm »
what do you mean by "from the one way valve"? You can't put it on the servo side of this valve as it only ever sees vacuum there.
Winston
Reply #3 on:
May 04, 2011, 12:19:33 am »
My one way valve has about 4 feeds that are blocked off manifold side... I will get a picture.
I think it came from a Corrado... It was just one I had lay about.
Good idea on the garden centre shout
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Turbochargers
Boost gauge feed
