request required pics update
Started by gavin.starr, April 29, 2011, 07:04:20 PM
gavin.starr
Is there any one in or around near Preston Lancashire that would be willing to drive there G to mine. Just for the sole reason of locating where all the vacuum pipes go to and from and to follow your loom and see what is missing from mine.
It would only be for around an hour or so just to cross check everything
It would be a great help
Gav
G40 AD
hi mate - not really got time to make the trip but if you have any particular questions or want pictures I should be able to sort whatever you need today...
cheers ad
gavin.starr
#2
Im just after finding out where some of the pipes should be leading off to. And what the bracket is in the last pic.
In the first pic i have two pipes that t piece out from the vacuum pipe to the master brake cylinder.
The second pic i want to know where the bottom and the clear/brown pipe goes too, i think by looking at it, it may go to the charcole  canister.
In the third pic what attaches to the little brass elbow at the bottom of the throttle body.
Gav
top  - one goes to fuel pressure pod on fuel rail, other to ecu
2nd, it goes to a pipe under inlet manifold with a t in it. (inlet to isv)
3rd goes to the top of flying saucer in 2nd pic
4th - its an additional charger bracket, mounts to exhaust manifold/engine mount/outlet dome
DKnight
etka is your friend it shows them all on there if i recall, will pull picture off if i find time
gavin.starr
Just another quicky, Do I need to purchase a new coolant pipe from the heater matrix to the coolant pipe at the back of the block.
The standard pipe on the polo block has a larger fitment than the one on the G so my hose is too baggy, I haven't got enough length to pull some through and chop it to fit.
Gav
these are early/late spec i believe so you need an earlier one i think, which tend to be smaller.
gavin.starr
Cheers Pete.
I shall get on the hunt for one
gavin.starr
Another quicky, Fuel pipes is it worth me cutting the banjo bolts off the end's to make them fit the fuel rail, or should I buy some G40 specific ones and jubilee clip them on.
grungeisdead
if the existing will fit without kinking just cut them, and jubilee them onto the fuel rail.
86C
Just cut them down to size and jubilee clip them. That's all I did 14 years ago and they're still there now :D
gavin.starr
where does the vac pipe from the bottom of the flying saucer go to?
see my post above!! goes to bottom of inlet manifold!!!
gavin.starr
#13
Quote from: PeteG40 on May 04, 2011, 06:01:08 PM
Sorry pete i seem to have confused myself
In my first pic there are two vac pipes coming from the brake servo pipe, the top one goes to the fuel pressure pod, where does the other one go to?
The flying saucer the top one goes to the brass elbow in my third picture. and the bottom one goes to the T-Piece under the manifold, And the brown one goes to the charcoal canister.
Is that right just to confirm.
DKnight
the other one goes the the ecu i think?
