Ignition problem
Started by matthg40, April 25, 2011, 09:14:59 PM
matthg40
Rite I have the most random problem ever when I'm driving my polo every now an then my car cuts out the alarm goes dead as does the ignition and dash panel everything else stays on. I have no fuse problem my ignition simply dies and doesn't not come back on for hours any body have any ideas what the helps goin on I can't explain this problem in any more detail sorry all somebody please help many thanks
Is it an alarm and immobiliser?  I'd guess at it being that
matthg40
Yea it's not a great one either it's a laserline
86C
Check the switch on the back of the ignition barrel. I had one go just like this some years ago. Replaced the switch and all was good.
matthg40
Ah good thinking and where's best to get a switch mate
Richg40
I used to have a similar problem, sometimes when indicating the ignition would go off and the engine wouldn't start. I reckon it was the laserline immobiliser.
matthg40
What's the best way to test if it's the alarm or ignition switch at fault
hmm well you'll probably find that the immobiliser part is wired into a couple of the leads going into the ignition switch and it laughably easy to by pass so I'd try that and see if the issues go away.
matthg40
Wicked thanks alot your always helpful many thanks buddy
matthg40
Sorry to bombard people with questions but what's the quickest way to bypass my immobiliser
Richg40
You need to find out where it is first.
matthg40
I know where it Is had the pleasure of finding it lol
matthg40
Rite I've found the alarm cables how do I bypass some one plz help I'm desperate I need my 40 back lol
Richg40
Dont bypass, find where it's wired into the loom, cut it out and repair the wiring.
