Breaks wont bleed
Started by 10pin, April 17, 2011, 03:23:00 PM
10pin
im trying to bleed up the whole system on my gt to g40 conversion and im just not getting anywhere i belive that its got a bigger master cylinder
fluid comes through but i have no pedal
it wasnt working i read though some topics on here then unhooked the load compensator and still no joy im just wondering if im doing anyhting wrong or you guys have and tips
cheers!
grantvw
Hi buddy if you just un do the pipes at the master cylinder to start with until fluid drips out ( Have a rag to hand to catch the fluid) do this on all three pipes on the master cylinder then try bleeding them again i would also recomend a gunson eazibleed kit it works off presure from a tyre to push the fluid through the system. Hope this helps Grant
10pin
Cheers i will try that im still unsure does the load compensator have to be unhooked when bleeding or can it be on as the car is pretty low when its connected its pulling it closed quite hard
you need to pull the compensator down to open it - not unhook it
10pin
Ahh i see so ive got it the wrong way round and the spring should be under tention pulling the top ove the compesator down pushing the bottom in? sorry to be a hasstle guys
samg40
Thats what we are here for!
