Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Turbochargers
2xGT1241 on G40
« previous
next »
Pages: [
1
Go Down
Author
Topic: 2xGT1241 on G40 (Read 4328 times)
Doc J
GT40 - AE86C
2xGT1241 on G40
on:
April 01, 2011, 07:44:11 pm »
Do someone thinked about 2 pieces of GT1241 on PY?
A simple schematic is attaches.
I know it will cost some money, but...
Would like to read about positives and negatives in this setup.
breadman
mk2 breadvan 1341 turbo sleeper (currently snoring
Re: 2xGT1241 on G40
Reply #1 on:
April 01, 2011, 08:35:41 pm »
Personally I'd have thought the extra weight of 2 turbos and the boost pipes/hoses complexity would more than out weigh any gains.
Administrators
The CV joint killer
Re: 2xGT1241 on G40
Reply #2 on:
April 01, 2011, 10:34:45 pm »
Not rally sure weight is going o be a factor. Fitting it all in will be though
Doc J
GT40 - AE86C
Re: 2xGT1241 on G40
Reply #3 on:
April 02, 2011, 07:41:37 am »
There is enough place with slim-line fan
gavin.starr
Re: 2xGT1241 on G40
Reply #4 on:
April 02, 2011, 09:16:57 pm »
has this been done on a G before. It would look pretty funky
Traders
I know naathing..
Re: 2xGT1241 on G40
Reply #5 on:
April 03, 2011, 09:48:46 pm »
If you've got the capacity to fabricate a manifold- then you can fit whatever turbo you wish, two identical smaller turbos won't spool quicker than one larger one.
More cost, more fabrication, more heat etc etc.
Positives- it's unique, nothing else.
gavin.starr
Re: 2xGT1241 on G40
Reply #6 on:
May 04, 2011, 12:10:45 pm »
The JZA80 Twin turbo supras come with a twins as a standard setup, one is for low down revs and the other starts to spool at around 4-5000 rpm, there is some complicated valves and wiring though to control them.
Which is why mine is just set for them to come on at the same time. as one of the valves broke and was going to cost £200 to replace it.
Pages: [
1
Go Up
« previous
next »
Technical
Turbochargers
2xGT1241 on G40
