Water pump leak
Started by matthg40, March 17, 2011, 09:58:25 PM
matthg40
Evening all erm has anyone experienced water leak at the pump I put a new pump on with gasket it was fine and now it's decided it wants to leak.it's not a big leak u could call it a constant drip all the bolts are tight anyone have any ideas thanks all
they could be overtight, they are only 10nm or something not that tight
also could be corrosion on the block...
or they do have an internal seal too - so could be the water pump.
pete
matthg40
I'm baffled because it's a new pump so if I've done the bolts a tad to tight that could cause it to leak
