Author Topic: What size fuel hose  (Read 3606 times)
Offline grantvw
What size fuel hose
« on: March 15, 2011, 12:01:50 am »
Hello i'm in the process of turboing my loon at the mo but it has the standard 1L spi fuel hose still fitted so will probably need upgrading but what size and brand have people used
Cheers Grant
Offline cheys03
Re: What size fuel hose
« Reply #1 on: March 15, 2011, 02:30:53 am »
It's the same bore AFAIK. From memory, according to ETKA there's only a bizarre joining pipe that's different between CL models and GT/G40. This pipe is near the engine bay. I'm pretty sure no-one has changed the fuel pipes for this reason though..? I've just used the existing pipes (originally a 1.3 SPI), no problems so far.
Offline Andy
« Reply #2 on: March 15, 2011, 09:33:57 am »
I've often wondered about this too, so when I was having random missfire issues borrowed Yoof's GT/G40 lines and measured them up. Couldn't find any significant differences, so am still running SPI fuel lines, albeit with a beefier fuel pump now. Don't have any issues - missfire was a dying hall sender...
« Reply #3 on: March 15, 2011, 11:04:46 am »
mine has GT fuel lines too.  I'm also fairly sure that all the injection lines off mk3 polo are basically the same.  You only need to swap if putting an injection engine into a mk2 as they only have low pressure lines for carbs
Offline Andy
« Reply #4 on: March 15, 2011, 01:07:17 pm »
GT are the same as G40 though Hayes - it's SPI/MPI where the differences are as Chris said. Either way, doesn't seem to make any difference - unlike fuel pumps!!!
Offline grantvw
« Reply #5 on: March 15, 2011, 04:24:54 pm »
cool i'll keep rocking the fuel lines i've got then one less thing to worrie about
Cheers Boys & Girls
Offline grantvw
« Reply #6 on: March 15, 2011, 04:26:13 pm »
Applauded everyone for the help even Haysey
