gearbox :S
Started by alan gorst, March 03, 2011, 04:12:56 PM
alan gorst
hi i am wondering if there is an alternative gear box i can use that would be just as good as a ATV? as im finding it really hard to find a ATV box for sale...any replys will be helpful :)
Thanks Alan
Justin14100
Quote from: alan gorst on March 03, 2011, 04:12:56 PM
Thanks Alan
8p is quite good, better than the GT one
yes the 8p which is just off a normal 5 speed mk3 cl is about as close to an ATV as you'll get.  Although they do have press-on diff crownwheels so no good for fitting a slip diff to.
CEG is the same ratios as the 8p, usually found on later mk3 polos.  Some of these are good for fitting a diff to, some are identical to 8p in every way.
