Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Turbochargers
turbo gasket solutions...
« previous
next »
Pages: [
1
Go Down
Author
Topic: turbo gasket solutions... (Read 2778 times)
shaun_89
on:
February 16, 2011, 08:35:42 am »
Im helping a friend sort his g40 turbo out at the moment. The first problem was a blowing head/manifold gasket.
A tubular manifold is being used and the gasket was blowing badly from number 4 cylinder.
Ive been told to use a 6n metal gasket in between two standard gaskets to make sure it doesnt blow again.
Is this overkill? What do you use on your turbos?
thanks
Administrators
The CV joint killer
Re: turbo gasket solutions...
Reply #1 on:
February 16, 2011, 09:29:42 am »
standard fibre g40 exhaust manifold gasket on mine. Who made the tubular manifold he has? maybe the flange is warped?
shaun_89
Reply #2 on:
February 16, 2011, 09:31:44 am »
Im not sure, it came on the car. Was from germany.
Ill get a rule on it later and check it for straightness.
Good to know the g40 gasket is fine, thought 3 gaskets was overkill!
Administrators
The CV joint killer
Reply #3 on:
February 16, 2011, 09:43:46 am »
make sure you get one from VW though, the GSF ones are a crappy piece of cardboard
shaun_89
Reply #4 on:
February 16, 2011, 10:01:07 am »
I always buy parts from vw
Dont trust pattern crap most of the time
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Turbochargers
