If you feel you need 5 gauges(oil pressure, oil temp, boost pressure, boost temp and fuel pressure, I presume) then I'd recommend some dual display gauges from SPA(check demon tweeks) they are pricey, but certainlydo the business as you can get all the info into 2/3 displays, alternatively if your budget is big enough then I'd fit a digital dash binical.
