Coolant help......
Started by dani1326, February 10, 2011, 07:55:34 PM
dani1326
Hay all iv changed my cambelt and water pump filled her back up with water and anti freaze but now the temperature is creeping up :/ is there an air lock on the or somewhere to release the air???
xandyx
there is a screw next to the heater matrix were you can purge the water system. unscrew and release the air inside the pipes. after that, check the level and refill if necessary.
greetings
andré
dani1326
Quote from: xandyx on February 10, 2011, 08:06:19 PM
greetings
andré
Take it that's going to be behind my dash as mine g40 is in a 6n... Shal I do it when its warmed up a little so there is pressure??
scotsjohn
Yes, best done when hot. Set heater control to max then crack the bleed screw(wherever it is) and wait till bubbles stop appearing, then close. Top up if required.
dani1326
Quote from: scotsjohn on February 10, 2011, 10:07:20 PM
Where is it eactly, on the heater mattes it's self, violent hoses or block
