Springs and shocksTA TechnixBudget german suspension kit, 4 uprated and shortened shocks, lowered springs available in -40, 60, or 80mm. Adjustable rear spring platform for ride height adjustment, about as good as your going to get without spending more than double. 2 year warranty - £140 delivered inc free top mounts.
4 Uprated shocks - £105 delivered.
Lowered spring kit - £70 delivered.
2 Front or rear shocks - £70 delivered.
WeitecWeitec offer the same 40mm, 60mm, and 60/40 spring kits.
£136 delivered.
Weitecs spring and shock kits available in the heights above.
£308 delivered for the 40mm and 60/40mm, but the 60/60 kit is £324 delivered.
![](http://img.photobucket.com/albums/v609/philj/ultragt_zps3f35e4aa.jpg)
Picture is a generic picture.
KWKW Spring kit - 40mm, 60mm, or 60/40mm
£147 delivered.
KW Spring and shock kit available at the heights above.
£370 delivered. (£47 off RRP)
![](http://img.photobucket.com/albums/v609/philj/kw_zps2f82ff8d.jpg)
BilsteinBilstein B12 spring and shock kit. This will lower a G40 20mm, and a normal polo 35mm. An excellent kit with what is probably the best ride quality around. This combines the B8 shocks with eibach springs.
£470 delivered.
Bilstein B13 spring and shock kit. This will lower a G40 45mm, and a normal polo 60mm. An excellent kit with what is probably the best ride quality around. This combines the B8 shocks with KW springs.
£470 delivered.
Just shocks...
Front pair of B8s are £210 delivered
Front pair B6s are £206 delivered
Rear B8s are £144 delivered
Rear B6s are £140 delivered
4x B8s £344
4x B6s £336
![](http://img.photobucket.com/albums/v609/philj/bilsteing402_zps68cdcad4.jpg)
![](http://img.photobucket.com/albums/v609/philj/bilsteing401_zps70c7ee74.jpg)
CoiloversTA Technix coiloversCustom made strut requiring no strut exchange, height adjustable coilovers all round, very large drop if need be. TUV approved, good ride quality, lowered steering arm which helps reduce bump steer. £465 delivered.
![](http://img.photobucket.com/albums/v609/philj/Parade%202/14052010775555.jpg)
GazGaz adjustable coilovers, custom made from your old front struts (may be able to arrange exchange/spare struts) Bump and rebound adjustable on a 3:1 ratio, custom spring ratings to suit your needs. They come with a 2 year warranty, the rears have been chrome nickel plated, and the fronts black zinc coated. £695.
![](http://img.photobucket.com/albums/v609/philj/Picture0088-1.jpg)
![](http://img.photobucket.com/albums/v609/philj/Picture0022-4.jpg)
Gaz adjustable front shocks, these are standard size so fit into a normal strut and the piston has been shortened to suit a 60-90mm drop. Ride quality will improve, and they are bump and rebound top adjustable on a 3:1 ratio like the coilover units. £185 delivered.
KWKW V1 Coilovers. You can either send KW your struts in Germany to make these, or pay a surcharge (near £400!) And get that back when you send your struts in.
£894 delivered.
OthersBudget rear coilovers, very stiff, good for stopping those wide rear wheels rubbing! £120 delivered.
Super Pro polybushes, usually next day delivery -
Front lower arm set, inner and outter (both sides) - £65
Anti Roll Bar to chassis - £20
