g40 clearout!
Started by PeteG40, January 29, 2011, 07:03:54 PM
tinted rear clusters £25
g40 ecu £70
interior - no rips/tears.burns including door cards, rear bench slightly faded but seen better - late spec cards include seat belt retainer in the back. £75
windscreen £20 (green tinted, but pattern)
g40 inlet manifold £10 (bare)
g40 alternator £25
g40 head - needs a rebuild £100
g40 exhaust manfold and downpipe - catted £40
g40 midbox  - not sure if its pattern or gen.. will check and post relevant price when i get to it
g40 stock bbs 13x5.5 - been painted (home stylee) not a bad job with good nick centrecaps and tyres all with good tread £125
g40 throttle body, been dewedged - £45
g40 vw11 brakes - calipers, carriers discs/pads and braided flexis (will try to find rear flexis) £70
g40 front and rear badges - both matt black  £30 pair
g40 dizzy - £35
g40 engine mount - £10
g40 drive shafts £30 one boot has split
g40 water pipe £5
g40 isv £10
g40 airbox £20
boostpipes - £5 each
pickup preferred - can post if you pay!
Robin
Pete why does the head need a rebuild? I am assuming it's stem seals and a skimming that it needs.
well i'd rebuild any head before putting on. its done 100k without proof of one plus engine it came of - suspected overheating.  So skimming, valve regrind, new stem seals, maybe guides (mine and sam's place does a skim/pressure test, 3 angle cut on valves, all new guides and new stem seals for about £150)
GAF2
HI Pete, you still got the g40 cat for sale? i take it its in reasonable condition? How much posted to IV10 8UQ?
cheers grant
£50 posted for manifold and cat.  The bolt in the cat that the clutch strap bolts on to has snapped.  Could drill it out eay enough though.
GAF2
ok mate will get back to you through the week waiting on a reply at the moment.
cheers grant
86C
Let me know about the mid box please Pete.
youngprodigys
where abouts are you pete?
i want the G40 engine mount - so ifs its still here when finish paying off my new motor il be having it
the g40 engine mount that takes the charger???
its sold
youngprodigys
doddy1988
still got the ecu? and where u live as i cud pick up?
ecu still here - i live near barnsley/sheffield
pete
scollops5
hello,
do you happen to have the seats going spare or the struts?
can pay with paypal asap if you want
cheers
josh
