Author Topic: Throttle Sensor wiring  (Read 2861 times)
Offline DKnight
« on: January 29, 2011, 10:39:10 am »
im just sorting the throttle sensor on my conversion, and wondered if anyone knows what needs to go to where in relation to the wires!
Re: Throttle Sensor wiring
« Reply #1 on: January 29, 2011, 01:32:28 pm »
principle is this, that the full throttle switch only works above a certain psi of boost - say 6 so that you dont overfuel while the turbo spools.
Therefore you have to wire this switch in between the throttle body full throttle switch (which is the white plug on throttle body)
Offline POLO.P
« Reply #2 on: February 04, 2011, 09:30:42 pm »
is it necessary to remove the micro switch that is located inside the throttle body? I had seen it all stripped out on an earlier post on here.
« Reply #3 on: February 04, 2011, 09:39:57 pm »
I assume you are in no rush, I'll sort it out for you next time I'm round.  It'll be fcool.
