flywheel,crankshaft pulley, clutch cover torque settings
Started by dub-disaster, December 19, 2010, 03:20:37 PM
as title says whats the flywheel bolt,cranck shaft pulley and, clutch cover toprque settings that i should be using haynes give different values to autodata which one is the one that i should be using ?? for example haynes says crankshaft pulley is 80nm where as autodata says 90nm plus 120 degrees for a hex bolt , thanks
I've just always used haynes since I dont have autodata.
ill stick with haynes then, i was only looking at the auto data on a post on here as i left my haynes at work. just 120 degrees and 10nm more seemed like a big difference to me !
