Hi,
I have recently changed my hall sender this meaning timing the car up.
After that the car was running sweet, Except the revs were up to almost 2000, and if not they were bouncing from 1000 to 2000
So i did some research and thought it must be the idle screw.
I warmed the car up, removed the blue temp plug and adjusted till the revs with 1000.
All Sounded fine but when i restarted it it was juddering and sounding like the pistons were firing at the wrong times.
Do you need to set the timing after fiddling with the idle screw?
What could my problem be?
It feels exaclty the same when i refitted my dizzy and it needed timing.
Rich
