I only needed the extra space to get the new timing belt on as my new 6pk (couldn't find a 5pk that would fit) pulley that replaced the v-belt one is a bit wider and doesn't leave much space between it and the chassis leg! I still dont thing though that any pulley would come out unless the 19 bolt only connects the two pulleys together and the 4 bolts hold both pulleys ont the crank shaft! Is that the case?
