couple of g40 bits needed
Started by newt, November 02, 2010, 06:41:22 PM
newt
hi there
any one got the plastic oil seperator thingy that sits down the back of the block and clips onto the metal breather
im refitting the boost return pipes and need the plastic valve to meet the pipe and breather, when removing boost return pipes most people probably remove this plastic seperator and fit rubber pipe straight to the metal breather
also need a fuel guage sender for a g40 f any one has one, think they are the same as gt,mine is working fine just weeping fuel very very slightly
many thanks
james
i think i have the one way breather valve in the shed.
also fuel gauge sender? thats in the tank, confused how that would leak?
newt
Quote from: PeteG40 on November 03, 2010, 09:35:23 AM
ill take the plastic valve pete
it looks like my sender is weeping around the solder join where the pipes go through the round top part
will investigate more , as i only had a brief look and it was moist around the join, either that or there is a pin hole in the brass pipe (return side) and this is where its coming from
will confirm cheers
the lift pump/sender are the same in all mk3 polos.
will try to dig out the 1 way valve at the weekend
newt
Quote from: PeteG40 on November 03, 2010, 06:13:33 PM
thanks pete
ill of checked the lift pump assembly in more detail by then
