Engine
Started by Jezza-7, October 25, 2010, 09:10:26 AM
On the look out for a head, block and crankshaft, pretty much just a bare engine for a little project. In no rush to have this but let me know what you got?
I have a set of g40 inlet/exhaust valves out of a head with springs etc
I also have a g40 crankshaft in decent nick.
Are the valves standard? Im looking to get the head ported etc to become a bvh, unless anyone has one for sale?
How much would you be looking for, for the ckank??
Also forgot to mention that the bottom end i need is for a rebore too, so any condition really.
Idea is to get bvh, rebore bottom end, lightened crank, already have lightened flywheel, while i can still drive my car.
Is it possible to use other heads/bottom ends or is it best to stick with the py engine?
stock valves yeah - they can be used in a 1.3 head (same casting as a g40) an issue with the BVH is where to get the valves these days... jabba aren't doing another run.
as for the bottom end - others have used other blocks, but with tapped oil drain/knock sensor... but apparently they arent quite as strong.
if your interested in owt  - let me know - make us an offer.
Cheers pete will do.
A local place to me, TSR can supply the valves for the bvh so hopefully that will be possible to do.
