Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Superchargers / G-Lader
Belt tension
« previous
next »
Pages: [
1
Go Down
Author
Topic: Belt tension (Read 1999 times)
Belt tension
on:
October 14, 2010, 12:24:59 pm »
What is a normal tension for a the charger belt?
I have herd that if you can just about turn the belt 90 degress then that is a correct tension. I think people use that for timing belts, wether its the same for the charger belt?
Administrators
The CV joint killer
Re: Belt tension
Reply #1 on:
October 14, 2010, 12:46:24 pm »
are you talking standard twin v-belts or a toothed belt conversion?
If he latter then yeah I've always done it like a cambelt where the longest free section can be turned 90deg with two fingers.
If v-belts then as tight as you can possibly get them really!
Re: Belt tension
Reply #2 on:
October 14, 2010, 01:06:06 pm »
Would help if i mentioned, yes they are toothed kit.
Cheers for your help.
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Belt tension
