what do thease plugs do ?
Started by rochey88, October 10, 2010, 02:12:01 PM
rochey88
what do thease 4 plugs do?? my temp guage has decided it wants to top working??
but i need to know what thease 4 plugs 2........... 2 on the thermostat and the 2 single pin connectors on the head
Alexiskayak_7
At the firts pic:
Black: Water temperature sensor (gauge sender)
Blue: Water temperature sensor (ECU signal)
The two ones at the 2nd pic are oil pressure switches
The right one (i think) is for the oil buzzer
that's the wrong black sensor, it should be a two pin one like the blue one (except black!)
rochey88
Quote from: hayesey on October 10, 2010, 03:34:42 PM
but my guage worked before? lol think i should change it ??
it's definitely not the right type, I'd change it anyway.  What does the plug look like? Can't see how the standard one would fit.
Alexiskayak_7
Yeah... Hayesey is right... It should be a 2 pin... I mentioned that before, but i wasn't sure, if i was right...
Don't you see that you can not plug it into the wiring?
rochey88
Quote from: Alexiskayak_7 on October 10, 2010, 04:57:58 PM
thats odd the loom has that 4 pin plug on the end ?? ??? ??? wheres the bet place to get both them plugs from?
cheys03
Is the car a conversion or genuine g40?
If a conversion, has it has other, later VAG engines in such as an AFH or 1.6L? That would be a possible reason for the adapted loom.
possible someone has cut the original connector off but it seems an odd thing to do. Is this engine in a 6n polo or something?
hardchargin40
Why does it look like you've a pink gearbox? :D
