Polo NZ Turbo?
Started by jimmyb1982, September 29, 2010, 08:06:24 PM
jimmyb1982
A crazy friend of mine is on about turboing his NZ. I've told him to do the following first:
- High flow panel filter
- 51mm TB butterfly
- GT top end
- 4 branch manifold and stainless steel exhaust system
- NZ remap
What would he need on top of that to run a small low blow turbo. I've heard the MK4 Polo has a metal head gasket which could be used to space the head? What about management, injectors, cam and sensors - would he need G40 items for that?
Its a crazy idea I know but what do you guys think he will need and what is the smallest sized turbo avaliable?
- Jimmy B
sinister polo
not worth the agro!
it would be much cheaper and more reliable to use a g40 engine, they are designed to handle boost!
jimmyb1982
I thought it might be lol.
NZ already has a decent size throttle as it is two plates likes a gt.  Not sure swapping the head would give any gains either, putting the cam in should get a gt-spec head. They are lower CR than a gt so mint get away with a bit more boost. A mk4gasket will raise CR a bit though so I'd leave the standard one in.
cheys03
I'm currently gathering the parts for an AAV turbo which is basically the same bare engine as the NZ, just with SPI instead of MPI injection. Same 9.5:1 compression.
Have a look here:
http://www.polog40.co.uk/forum/index.php/topic,4708.0.html
For a rough foundation.
I'm going down the K03 route, because it's tried, tested, relatively cheap and there are lots of parts available. It'll run G40 management with a chip from PPP to start with, probably a custom remap once I'm comfortable with a boost figure - starting around 5-7psi on recommendation from the forum. I'm sure at some point the boost will be increased incrementally until something pops - to find the limit. Hopefully it'll just be the head gasket.
However...when you add it up you're not saving much by keeping the NZ/AAV over a G40 conversion minus the charger.
