Author Topic: suspension/rear axle???  (Read 2973 times)
Offline Jake G 4 0
  • Rebuild time almost over
« on: September 28, 2010, 09:37:49 pm »
I recently bought some koni dampers and springs. I have fitted the rear drivers side with ease but the rear passenger side the bolt holding the old damper in place that goes through the axle has rusted inside the sleeve of the damper and impossible to get out. I have tried everything i cut the head off and tried hammering it, heated it up and i drilled it today which didnt go to well :( i drilled through a tiny bit off line and missed the other end by 1-2mm.
I was just wondering if anyone else had trouble like this and any solutions to my problem.
Thanks in advanance for any input or solutions.
Jake
Offline Jezza-7
Re: suspension/rear axle???
« Reply #1 on: September 28, 2010, 09:45:24 pm »
Not got round to that area yet, thats on the to do list.
But here are the part no.s for the bolts and nuts if needed?
bolt 861513471
Nut (self locking) N 0221671
The bolt comes up as "screw" at vw as i found out earlier today.
« Reply #2 on: September 28, 2010, 10:03:36 pm »
get a hack saw and cut the bolt either side of the shock, but within the square hole of the axle if you get my drift.
Nasty job but only way to get it out really
pete
« Reply #3 on: September 29, 2010, 09:38:36 am »
quite a common thing, happened to me a few years ago.  Like Pete said, pretty much the only way I could see is to use a small hack saw blade and cut through the bolt either side of the shock (well, you can just grind the head off it on one side).  It's not a nice job and your arm will ache like mad by the end of it :)
Offline Jake G 4 0
« Reply #4 on: September 29, 2010, 11:01:34 pm »
Thanks for all the advice and comments lads I got it iff today I had to buy a mini long bladed hack saw and spend an hour and a half cutting through the side of the shock :/. Like hayesay said my arm is aching now :P
Thanks Lads Jake.
Offline youngprodigys
  • G 3URO
« Reply #5 on: September 29, 2010, 11:56:24 pm »
I had a similar problem when my bolt got stuck in the axle.
i got mine off with an irwin stud remover, soon got the nut on the inside of the axle locked up and i simply used a socket then, however it did cost me £21 for the set of irwin sockets, but a great tool to have in the tool box as they get any rusted/fubar bolts undone
did it not turn then fella? to loosen it up a bit?
« Last Edit: September 29, 2010, 11:58:04 pm by youngprodigys »
« Reply #6 on: September 30, 2010, 08:51:40 am »
they normally turn fine.  But turn the whole of the suspension leg bush as well!!! its the bolt that rusts to the bush.
Copper ease the whole bolt when reassembling!!!
