What the hell!?
Started by wbaxter90, September 07, 2010, 05:06:07 PM
wbaxter90
right, ive been in canada for a month, got back to a g40 with a flat, fucked battery, so i changed it, started up fine, then went and put my new charger belt on, as the old one snapped before i left. started the car up after and it sounds like its running on 3 cylinders, it will misfire constantly while driving and cut out when pulling away sometimes, didnt do that when i left the country? whats going on???
vwmk3jon
wbaxter90
checked dizzy - nothing
checked plugs - nothing
took a plug out and they seem fine?
liam
have a look at your ht leads.
vwmk3jon
Is it the same when it's upto temperature?
wbaxter90
yeah we let it run for ages because it hadnt been used in over a month, then took it for a little drive and its running on 3 cylinders, really lumpy, cutting out, and foot down in any gear theirs no power at all but you feel it going back and forth in and out of power if you get me like missfires?
wbaxter90
rite, my car has gone from running (badly) to now not even starting and when it does it runs on 1 cylinder then cuts out. what the hell is up with it? it was fine before i went on holiday, came home put a belt and a new battery on and its worse! why is this? really contemplating selling it
Puncharado
Is the fuel OK? Could be way off, but I'm thinking condensation in the tank after being sat.
xandyx
check for crack on distributer cap. if it's cracked, it may have some steam on it. in that case, open the distibuter cap, check the paper washers and replace them, clean the cap and spray wd40 inside it and see if works.
wbaxter90
changed dizzy cap with new one and replaced arm which was surprisingly worn with a new one. the plugs all spark so i think its the plugs also my engines flooded :(
