Non g40 crankshaft pulley please
Started by dub-disaster, September 07, 2010, 01:29:33 PM
As title says non g40 (normal polo) crank pulley please kinda need it in a hurry thanks pm me if you've got one thanks
weirdly there are two sizes (and part numbers) for these - early and late.  One is considerably bigger than the other.
Anyone know why? and which is best to use?
pete
I do remeber something about this, in wich case a matching pair of cranshaft and altenator would be ideal realy I did have a set but i have lost the crankshaft pulley !!
hmm wasnt aware of any difference, I suppose you should get a matching pair (bottom pulley and alternator pulley) from the same car to ensure you don't over-drive the alternator or drive it too slow to generate enough power.
Etches
I presume this is when going turbo was guna ask a few questions myself about wether you have to change the bottom pulley but i guess that you do!
cheys03
I've got one of each sat on my desk here. The smaller is ~100mm diameter inside the V where the belt sits and the larger ~115mm.
I'll send you a PM
