Author Topic: indicator shenanigans..  (Read 6090 times)
Offline deevub
« on: September 02, 2010, 10:32:01 pm »
having a peculiar intermittent issue with indicators at the moment & was wondering if any of you have had similar or heard of anything like it?
indicators work fine one minute, then the next time you try, the dash light goes on solid & there is no 'on/off' flashing going on.
then next minute, fine again..
just had MOT, she failed on hand break efficiency & fog bulb so [not too bad for 19yr old!] replaced rear shoes & new bulb, so re-test tomo, but the indicator problem wasn't picked up in the test.
any ideas?
Offline Puncharado
Re: indicator shenanigans..
« Reply #1 on: September 02, 2010, 10:57:58 pm »
Dodgy relay.
Offline deevub
« Reply #2 on: September 02, 2010, 11:00:53 pm »
many thanks!
« Reply #3 on: September 03, 2010, 12:32:20 am »
i had this with a dodgy stalk too
Offline AdzCM
« Reply #4 on: October 01, 2014, 01:50:31 am »
This is similar to a problem I am now having, except mine is not intermittent. I turn on the indicator and the green light stays on but no indicator.
My hazards come on though when I press the hazard lights button.
Could this be relay or indicator stalk?
If so, where is the indicator relay located and will any mk2f indicator stalk be the same?
Adrian
Offline sleag40
  • Poloist
« Reply #5 on: October 01, 2014, 06:38:18 am »
I believe all indicator switches are the same - relay should be marked 21 and can be accessed by removing the shelf under the glove box. Its clipped to the bulkhead with another relay numbered 53. Hope this helps!
Offline AdzCM
« Reply #6 on: October 01, 2014, 03:21:58 pm »
Thats perfect mate, thank you :)
Offline AdzCM
« Reply #7 on: October 10, 2014, 05:55:32 pm »
replaced the relay and its still doing the same. Faint green light on all of the time. turn on the indicator and the light goes a solid bright green and stays on but the indicators do not.
Could this be the stalk?
Anything else it could be?
I've taken off the plastic surround and all of the wires. How to you remove the indicator stalk? I take it you remove the steering wheels to get at screws or something?
Offline sleag40
  • Poloist
« Reply #8 on: October 10, 2014, 06:31:15 pm »
A short circuit can do this - if the fuse has popped theres a good chance a short is the problem.
The stalk is held on with 3 screws which the steering wheel needs to come off to get at.
Is the fuse still intact?
« Last Edit: October 10, 2014, 07:08:49 pm by sleag40 »
Offline AdzCM
« Reply #9 on: October 10, 2014, 08:54:00 pm »
Thanks for that mate.
Where is the fuse for the indicators located?
Is it in the little box in the opposite side to the battery tray?
Adrian
Offline sleag40
  • Poloist
« Reply #10 on: October 10, 2014, 08:58:18 pm »
Aye, its under the clear plastic lid - fuse number 10 I think.
Offline AdzCM
« Reply #11 on: October 10, 2014, 09:54:56 pm »
Thanks again. I'll check that now...
Offline AdzCM
« Reply #12 on: October 10, 2014, 11:19:36 pm »
You are a legend mate! That's exactly what it was.
Where the heck would you get one of those fuses lol? What rating is it even?
Thanks again!
Adrian
Offline AdzCM
« Reply #13 on: October 11, 2014, 03:29:54 am »
Scratch that. Think its an 8A ... Found a wreck of them on ebay.
Offline Jezza-7
« Reply #14 on: January 24, 2017, 11:28:33 pm »
Bringing up a thread from the dead,
I have got a very similar problem with my car, now i checked the fuses after a previous short circuit problem and they are all fine. Im yet to swap a relay over.
I will double check, but i think when i select left or right i got no response and the light stays green. Hazards work fine and can hear the relay clicking away. I have got a spare stalk but i don’t know how that could be a potential cause?
