signal wire colour from lambda
Started by vwmk3jon, August 23, 2010, 03:13:38 PM
vwmk3jon
Just need to connect the signal wire up from my AFRG and its working :)
Had a look at the wires from the lambda - 2 are white and 1 is black which i assume is the signal wire. Is this correct?
(note: i dont have a multimeter to check)
its the purple one in the loom. i know that!
it's one of the white ones if I remember correctly from the probe to the connector so pretty hard to tell which one.  It's the purple wire from the other side of the connector to the ECU so you need to look there.
vwmk3jon
Black wire Paul :)
got it connected now. Just gotta wait for it to stop raining so i can put everything back together (bloody english summer!)
vwmk3jon
Errrrr kinda. The light flicks round to lean when I drive normal and then goes out (mega lean maybe?) I'm gonna check and re-check the connections but the light stays on optimum when idling.
it should fluctuate between lean and rich at idle.  But then I'd assume it'd not do anything at all if you'd connected it to one of the heater wires.  Is the wire on the other end of the connector purple?
did you ever get it remapped or is the fuelling probably still not right anyway?
vwmk3jon
Traced the wires up from the lambda to the plug and then found which colour wire connects to the purple wire and joined the signal to that.
Still not been remapped yet. Had to spend the cash I had set aside on unexpected bills :(
yeah fair enough.  it'll probably explain why it seems a bit weird so I'd say it's wired correctly
vwmk3jon
Must be uber lean. If i coast down the road, i get a light on (fluctuates as you said). Foot touches go pedal and it dips down and beyond bottom of lean :(
poloeatonm45
i have mine connected to the purple wire and mine reads really lean quite a lot maybe i should get a propper remap soon
Well to be honest the normal narrowband probe is pretty inaccurrate at best and so are some of the gauges.  Can only really tell for sure with a wideband probe but lean isn't good!
