Author Topic: Turbo Bits General help  (Read 5979 times)
Offline Andy
Re: Turbo Bits General help
« Reply #15 on: August 24, 2010, 12:34:33 am »
To be fair, if your chassis is mostly standard, you're far better off aiming for 175bhp at 15psi on a standard MAP sensor and saving for chassis mods. A standard G40 chassis with no subframe isn't so bad with a K03 turbo'd 175bhp, but if you wind the boost up to 21psi (approx 190-205bhp depending on bottom end) then you need to start thinking about how to get the power down.
« Reply #16 on: August 24, 2010, 09:19:47 am »
Hmm I'd say the same for 175bhp really, mine was pretty wayward with about 150bhp (back with the g-lader) on a track day without the subframe and diff.
Offline Etches
  • Still got the G...
« Reply #17 on: August 24, 2010, 10:24:37 am »
I already have a wishbone conversion which is fully poly bushed , with uprated rear engine mount and I have a metal gb mount too
