Turbo Bits General help
Started by Etches, August 13, 2010, 06:39:06 PM
Andy
To be fair, if your chassis is mostly standard, you're far better off aiming for 175bhp at 15psi on a standard MAP sensor and saving for chassis mods. A standard G40 chassis with no subframe isn't so bad with a K03 turbo'd 175bhp, but if you wind the boost up to 21psi (approx 190-205bhp depending on bottom end) then you need to start thinking about how to get the power down.
Hmm I'd say the same for 175bhp really, mine was pretty wayward with about 150bhp (back with the g-lader) on a track day without the subframe and diff.
Etches
I already have a wishbone conversion which is fully poly bushed , with uprated rear engine mount and I have a metal gb mount too
