fuel relay problems
Started by packers, August 12, 2010, 11:05:22 PM
packers
Hi my  latest problem is the car died earlier today ,and after towing back and
investigating problem found no fuel pressure . there is 12v going into fuel relay
on red wire + another 12v on black wire which i am taking is the supply for relay coil going
from haynes manual. the turn on signal appears to come via lilac wire frome ecu which i am assuming provides a ground for relay coil and turns the relay on . any ideas where i should be looking  or testing next to prove or disprove ecu problem.
