1 and 2 gear difficult to select after a speedy 50Km drive.
Started by mstar, August 08, 2010, 08:35:19 PM
mstar
Hi all, after a speedy drive downshifting to second and first goes a bit difficult, does this indicate to worn gears or clutch or just need a oil change? I don't know when it was done, previous owner didn't do much maintance.
Do the two HEX bolts to fill and drain the oil have a seal that can be re-used? Is there anything special to consider when changing the gearbox oil?
Thanx for the help.
Alvaro
Hi, if i was you, i would changed the gear oil.
beleave me, the gears will shift much better.
mstar
Thanx
What is the easiest way to fill it again? use funnel with a tube?
