oil cooler pics
Started by Jake G 4 0, July 13, 2010, 04:35:49 PM
GAF2
right guys, this thread has got me into gear to fit my kit (had it nearly a year) but went to look at my sandwhich plate and am not sure if its right, it is thermostatic controlled but to me it looks like the thermostat is in the open postion. see pic below.
http://i364.photobucket.com/albums/oo82/GAF2_photo/oil%20cooler/SDC10508.jpg
also does it matter which pipe you put on to which outlet, i was thinking no because it doesnt matter which way the oil runs through the cooler?
i imagine the side of the sandwhich plate with the rubber seal on goes against the block because the filter already has a seal on it?
http://i364.photobucket.com/albums/oo82/GAF2_photo/oil%20cooler/SDC10509.jpg
one last question and might be a bit stupid, with a kit fitted do you need to increase the amount oil you put in the engine or do you just continue to fill to the level on the dipstick
cheers guys
Quote from: GAF2 on July 16, 2010, 03:52:42 PM
Im not 100% sure
Quote from: GAF2 on July 16, 2010, 03:52:42 PMalso does it matter which pipe you put on to which outlet, i was thinking no because it doesnt matter which way the oil runs through the cooler?
Is there not any arrows for the flow on the side?
Quote from: GAF2 on July 16, 2010, 03:52:42 PMi imagine the side of the sandwhich plate with the rubber seal on goes against the block because the filter already has a seal on it?
Yes thats right
Quote from: GAF2 on July 16, 2010, 03:52:42 PMone last question and might be a bit stupid, with a kit fitted do you need to increase the amount oil you put in the engine or do you just continue to fill to the level on the dipstick
cheers guys
Yes you do, but run it till the engine is warm enough for the thermostat to open as there could be as much as half a litre in the oil lines and cooler, depending on size.
GAF2
cheers jezza, na no marks indicating flow jus says mocal on it. thought you would have to increase oil level just wasnt 100% sure.
anyone got any thoughts on the position of my thermostat, heres another pic
http://i364.photobucket.com/albums/oo82/GAF2_photo/oil%20cooler/SDC10507.jpg
Cause i got the same oil plate i will see how mine is mounted in the morning and i will take a pic and post it on here.
That way i guess it cant be wrong as mine has never had a problem.
GAF2
This is how it is on my car
and my cooler sits behind the grille
Robin
mines behind the grille, i was able to get a mocal one to sit behind the grille so its out the way.
