i read up on the hall sender and the symptoms and they do sound very similar, i cleaned the dizzy out, rubbed the spark points etc but it didnt do jack!, when i finally got it started i took it for an hours drive, it feels lumpy on idle but does even out when hot, it drives ok, but since owning it, it does feel like its lost power even though iv change the fucked alloy pulleys to steel ones and a remap chip in!?
sometimes its fine and sometimes its groggy and slow feeling. even though it did it before the remap chip and ignition timing, do you think maybe my timing has been done wrong? also after a while i started hearing a rather loudish tapping from the engine? even though it had a full oil and filter change last week? oh and also lol when idling i can feel like bumps and vibrations under my seat and through the pedals every now and then? sorry to go on and on but im trying to give you as much symptoms as possible.
could someone please post links to the right dizzy and leads i need to buy, much appreciated guys thanks for the help
